Gonefishin95
Thread starter- Joined
- Aug 16, 2009
- 44
this is gonna be my last post for awhile, im sick of 2 strokes and ill stick to stroking 4.0's
first off a little history as to what ive done on the johnson seahorse, 1966 20 horse.
~new coils
~points
~condensers
~rebuilt the carb (i guess you can say ive done this about 4 different times if you include the amount if taken it apart and cleaned it)
~new water pump, complete unit not just impeller
~new plugs
~compression checks out to be almost exact for each cylinder.. (119/117)
~new 50:1 fuel
no matter what i do it always seems to run like garbage, ive tried it in a bucket and out on the water. WHEN i can get it to actually idle for an extended period of time (over a minute) i need to constantly adjust the Low speed needle, but it still spits and what not and tries quitting. I also almost always need to use starter fluid to get it going.
two issues i know might be a problem...first, the top plug when taken it after the running is wicked charred, which is odd because its new, the bottom one is normal. the second issue is where you hook up the fuel line to the motor. the plug leaks?
sorry for the long post, any help advice would be great
thanks
steve
~new coils
~points
~condensers
~new plugs
~new 50:1 fuel
thanks
steve
