Experts,
I bought a 9123r evinrude with some troubles. Most off the troubles are fixed already because two days later i bought an 9222 with an stuck engine for spare parts.
I've already fixed the carberateur, the propeller, fuel pomp and a few little things. Yesterday i've tested teh engine (9123) and it run but not very nice. The main problem is that is losing gears at 20%power and up. I figured that the gears are worn aout so i'll change them for the gears from teh 9222. I'v already disconnect the tailpart (everything on this picture http://www.boats.net/parts/search/BRP/Evinrude/1972/9222M 1972/GEARCASE/parts.html) from the 9222 and tonight i will do the same with the 9123. The only thing i don't understand is ho to make the connection for the shift shaft (no 45 on the drawing) because when i assemble the gearcase to the rest of the enige i can't secure no 52 because it's inside the housing. So i wonder maybe i'm not assembling in the right order?
I hope you see my problem and have a solution. I'm dutch so pardon my english
Greetings
Klaasjan
Greetings
Klaasjan
