Most of all I'm looking for an impression from folks that have had a lot of experience with drive repair and changes of how bad it is that I had some very small metal shavings on the magnetic plug when I drained the lube. and some of the lube was burnt looking. Alpha gen one, 1.8 gear, original upper, sei lower. more details below for those who feel like reading... thanks!
My water pump impeller gave out the last time I was out and so I went to change it yesterday and when draining the lube, I found some small slivers of metal on the drain plug magnet (no big chunks) and the lube was much darker than usual. Pulled the cap on the drive and found the upper gears coated in burnt looking lube and with a few dark looking spots on them, but nothing to indicate that they were demaged - no unusual looking wear patters nor anything so blatant as a chipped tooth. The upper roller bearings and cup look fine and aside from the dark, burnt looking lube coating the upper gears, everything looks fine. I haven't had any noises or anything that would indicate a problem with the lower end. I should have checked the lube level before draining, but checkked it a couple of weeks ago and it was full so I didn't think about it. If it was low, it wasn't very low based on what came out.
The current drive is an original 1988 upper that I've run hard and long for several years on top of an SEI lower that I bought a few years ago. There has typically been a little very fine metal "sludge" on the plug and sometimes one or two fine slivers, this time there were more, but not enough that I got any more by filtering the lube. There were also a few lighter colored streaks in the lube (small amount of water?). I changed the lube and sealed, pressure tested and painted the drive just a couple months ago and it probably has 30 or 40 hours of run time on since. This was merc hp gear lube. I had been running mobile one, and never had a problem, but that could just be a coincidence as I've run the merc stuff before. I'm not running a drive shower, but last year had a thermocouple installed for a while to measure the lube temp in the upper housing and even running hard it never got so hot I was concerned. I need to change gear ratios as I'm maxed out on props with the current one and just cryo-treated a new set of hardened 1.62 gears and new bearings, but am not ready to invest the time right now to carefully put an (my first) upper together and was going to do that, a sternjack and possibly a shorter drive if I run across one at the same time when things slow down at work. If my lower is in good shape, I don't want to gernade the upper and need both, so I'm at a bit of a delima. do I:
1. change the impeller, put it back together, pressure test it, fill it and take the kids boarding. Check it often for a while. (I normally have been changing lube at from 25 or so to 40 hours max - I'm hard on things sometimes and know it).
2. order a new upper from sei so when I get the other built I'll just have a good spare.
3. ???
The machine shop owner had really nice alpha drive that they had apprently set up for someone else he said he'd make me a hell of a deal on if I needed one a year or so ago, so either way I'll check to see if he still has it and want's to get rid of it. Was in the same breath he gave me some really nice accessories, ie gaffrig, etc... and offered a hydromotive prop (wrong pitch range), so I'm assuming hell of a deal would be an attractive price.
3. ???
