altondrive
- Joined
- Aug 30, 2009
- 4
I installed a new tach but didn't have the pole set correctly. I reset the pole and the tach would come up to about 500 rpm on start of the motor then back to 0. I bought a second tach and installed it with the pole set correctly. Started the motor and got the same thing. If I unplug the green wire going to the tach and touch it back to connect I get the same jump on the tach but again, back to 0. The ground is solid, the ignition wire is solid, the tach signal wire is solid at the tach. The amp meter registers the motor is charging. Where else to look for the problem? Obviously the first tach is good too so now I have invested in two tachs and neither work. Explain that to the wife!
Both tachs are analog.
Thanks in advance for any help you can provide!
