1988 Johnson 4HP 2 stroke, starter cord won't retract. Please help!
zsistadivine
Pulled on starter cord this a.m. to go fishing and cord would not retract. :confused:
Vic.S
Re: 1988 Johnson 4HP 2 stroke, starter cord won't retract. Please help!
Spring broken ??
Rick.
First thing to try is a rag under it and then spray lots of wd40 into the spring area. Can you still see the small coil of spring out side the spring cup towards the back? If not your spring has retracted into the cup any you will need to pull it apart for that fix. Best of luck. Rick.
