marc67john
Thread starter- Joined
- Aug 30, 2009
- 15
I have a 1967 johnson 20hp. that when in drive it is not getting all the way up to speed. Its only going about a 1/4 of what its supposed to. I've had some problems with it. First off the seal's where bad in the lower gear case and cracked the scag over the winter. So i had is welded up so the water doesn't damage the gears. So when i put it back together the motor started jumping in and out of gear. So i adjusted the "gear shifter" where you shift from forward and neutral and reverse with the screws on it to get it to go into forward so it wouldn't jump in and out so it ( Completly engaged). Which brings me to my new problem of only going 1/4 of its speed. It starts fine and idles great. and reve's all the way in neutral when i do it with the throttle. But not in forward. Any suggestion???? model #20 R- 69B 1967 johnson 20 hp. p.s. checked the carb and it seems good.
