retrorocketz
Thread starter- Joined
- Jun 24, 2009
- 3
I have a mercruiser alpha 1 with a 351W ford engine. I got water into the bilge area (a lot) so, following the advice of what i could find here and on the internet elsewhere i removed the outdrive to check the bellows. No water in bellows and can't find a tear or anything. Got the bellhousing removed, and i am putting in a new gimball bearing. However after cleaning up the bellows tubes to reinstall, i used compressed air to blow the gunk out that i had cleaned off. I got the air close to the exhaust tube, and when i did, water came out of the water supply tube that is located above the gimbal bearing. To double check, i purposely shot compressed air in the tube and immedieately more water came out of the water tube, A lot of water. Is that normal? do i have an exhaust manifold leak somewhere? Could water get into my bilge area from this? I assume that wouldn't do it, because i wouldn't have any pressure in the system ( the air would leak out somewhere before it pushed out water). I am not sure what my next step should be, any advice?
