Question about where to connect battery cable
ColaTM
I am looking at a I/O Volvo Penta that says "220E" on the manifold and it's a 1986 V8.
The Positive battery cable is not connected and I am not sure where the starter is on this boat.
Is there a link to a manual on here (I've searched but can't find one) or can someone tell me where to look?
Thanks!
Re: Question about where to connect battery cable
Ayuh,... Down Low, Aft, starboard side of the Block...
jtybt
Do you have a master battery switch? Most are red and 5-6" in diameter.
Hmmm...have you ever attached the battery cable to a starter before? I wonder if you might want to have someone help you the first time.
boat1010
Smiling.... I just hope that when you are saying starter you actually mean solenoid. Good luck with your project.
ColaTM
Mystery solved. No starter installed. Found it under a seat along with solinoid. Gotta replace and go from there.
Thank for all the help! As usual, this forum is like having a few hundred experts staning right beside you!
