We got there....but..
2mate
Guys shes fixed! Impeller was stuck on gear shaft :eek:
But now she is running lovely :D i was wondering if there is a way that i can "tune" the engine to maybe make it 3hp just out of household tools..Ive tuned her to what i think is the Optimum and was wondering if there is a way to give her more go! Also i have been running her on 100:1 mix and read in my manual that omc decided 4 years later to run them on 50:1 so i am going to do this tommorow. I also havnt changed the gearoil for 3 years :rolleyes:
So i have ordered some Star Brite High Vis Gear lube which should be coming soon. Do i just drain the old oil and poor this one in?
Any help or suggestions welcome :p
jonesg
Re: We got there....but..
It would help if you posted what engine this is, yr , model number etc.
Usually you pump the new oil from the lower fill hole til it comes out the top.
Don't remove the philip screw under any circumstance, thats the shift fork retainer.
Sometimes ( everytime) those drain screws are very tight and only an impact screwdriver will pop em loose when tapped with a hammer, cost about $20 but very usefull for stubborn screws.
Inspect oil for water, use NEW seals on screws or you WILL get water in the new oil.
watch a video,
http://www.youtube.com/watch?v=Wj0l...C4C4AFEF&playnext=1&playnext_from=PL&index=17
2mate
Sorry!it's a 1984 evinrude 2hp seriel e2cers currently running 100:1 mix
jonesg
1984? shoot, thats not even broken in yet.:p
Give it another 10 yrs.
2mate
Haha well the oil has come I've never changed this before:s my 2hp has one drain plug next to the prop ocording to the manual I drainit from there then tip the engine up and poor it in ,i don't think it needs to be pumped
Lion hunter
I don't think I have every seen one with only one plug. Theres not a similar looking plug about 3-4" above the drain?
2mate
Below is a image of the lower leg any ideas? I can only see one plug
[/IMG]
jonesg
Looks like it only has the one screw then, never seen that.
Just make sure theres a seal on it and its TIGHT.
Then gas up and release the hounds.!
2mate
You learn somthing new everyday :D
On the subject of gas...should i changed to 50:1 mix as it say on my engine 100:1 but then i read in my manual after 1988 omc suggested run them 50:1 :confused:
wilde1j
A lot of pre-1950 motors have only one.
Use 50:1 (100:1 was a mistake).
2mate
Ooh ok what diffrences should I expect peformance? Any like that
