I have a 1980 Chrysler 105 outboard that is giving me problems with starting. It cranks just fine, and I'll get the occasional backfire, but it will not fire up and run. Here's what I've tested:
1. Battery is new, has good charge, voltage-drop tests fine.
2. I get a 12v reading at the blue (ignition circuit) wire with key in run position.
3. Gas in the tank is old - don't know how old but I've squirted fresh 50:1 mix with a spray bottle directly in the carbs without firing success.
4. Spark is present on all four cylinders as tested by pulling each one and holding near engine block during cranking. They all make a bluish arc - is there such thing as a bad or weak spark?
5. Plug tips are shiny (not sooty) but are wet with gas when I pull them.
6. Choke works when pushing key in.
7. Another thing I thought I should mention is there is quite a bit of unburned 2 cycle oil coming out of the prop area.
What other tests can I run or items should I test to get this running?
Thanks in advance!
Thanks in advance!
