wire size ???
timbecht
my boat had 10awg wire from rear to trolling motor and then 10awg from rear to helm and then 10awg from rear to auxiliary switch panel i am going to put all new wire in and need to know if 10awg wire will be ok to replace the old 10awg wire the trolling motor is 12volt and if it is what size circiut breakers to put in and for which things
trolling motor fuse size and circuit breaker
helm circuit breaker
auxiliary panel circuit breaker
need info asap
starting work this weekend
timbecht
Re: wire size ???
trolling motor is about 15feet
helm and auxiliary panel are about 8 feet
Re: wire size ???
Key factor missing -- what is the current draw of the trolling motor? 30 amps, 40 amps, 50 amps -- what? Tell us make model and thrust and we can give you an approximation but all we know is that it's a 12 volt motor. In most cases, 10 gauge would be fine for the accessories. At that distance it is probably not heavy enough wire for the trolling motor.
