Re: Merc Cruiser Tilt/trim
You can just use a screwdriver to jump the solenoids. Solenoid with blue wire is up,solenoid with green wire is down.Jump from large red terminals to blue for up or green for down.If it don't work be sure you have 12 volts at the large red wires.If you do have 12 volts and it doesn't work jumping to the blue or green then you have a problem in the motor. Also be sure the black wire coming out of the motor is grounded.
