Where can i get a snap ring trailer jack
kaliman91
I can seems to find and y place that sells these weld on snap ring trailer jacks with a wheel on it. Any suggestions on where i can get them. I would hate to put a bolt on jack.
Lion hunter
Re: Where can i get a snap ring trailer jack
Not sure what a snap ring jack is but farm supply stores usually carry every type there is.
jaxnjil
i know the jack your talking about. it ahs a bracket welded to the tong and pipe with a groove on the out side lip on the pipe. the jack slides on and rotates forwad and back and i held from sliding off the pipe by a 2" or so snap ring.
not sure where you are. farm and ranch and also utility trailer supplier. we have one similar to that one a snowmobile trailer. shellby is the brand name on that jack. it uses a cap screw in place of the snap ring though.
Lion hunter
I think I understand the type. We use all Bulldog brand jacks on our equipment at work.
fishrdan
I have a bolt on, on my jon boat trailer and a weld on, on my Crestliner trailer. They both used the same exact jack and it attaches to the base the same way, only difference is the base, 1 gets bolted on the other welded. If you want to weld it on, and can only find the bolt on, just weld it on. I looked, and the only difference in the bases is the weld on has a bit smaller foot print and no holes.
If you absolutely want a weld on, check a trailer supply store.
kaliman91
Yeah shelby is the brand. Found them online. Thanks.
