I have a ?75 Evinrude 25hp, model 25552B. I was having trouble with my carb flooding. I rebuilt the carb and replaced the float. The engine started but died after 10-20 sec. I adj. the float because gas was flowing out of the carb. The carb seems ok now but the motor only runs for 10-20 sec. I decided to check my fuel pump. Is this the correct way?
1. With carb still out, I connected a longer hose from the fuel pump to a jar.
2. I removed the plugs.
3. I checked the fuel line by pressing the bulb and gas flows into the jar.
4. I pulled on the starter rope a number of times but no gas flows through the hose.
Is my fuel pump bad? Also, the parts diagram and my service manual show a different fuel pump. Mine has 5 sides and looks like an ?85 model. Should I just rebuild it?
