badbowtie
Thread starter- Joined
- May 18, 2007
- 634
1985 wellcraft 260 hp alha one. I was crusing acrros the lake today to head down to the spot were we ski we were only doing about 20 mph and the boat made a weird noise didn't sond like clunk or anything sound like a rope or something get sucked in by the prop. I shut the but off and lifted the out drive went back and checked nothing. so I turned the key back on and the temp gauge was at 180 I let the boat cool and tried to start it. Started right up but would not move forward or reverse. I also had no water comin out the exhaust so I shut it right back off. Found a boater to tow me in got towed in and brought it home and started to tear into the lower unit. Drained the outdrive and noticed it had allot of metal in it. I pulled it off and tor it all apart pulled the spanner nut that holds the u joint shaft in. Pulled it out and the top cover and the gear that is straight down under the top cover and the one that is on the end of the u-joint shaft are missing teeth. Alll the peices were laying in their. I am wondering what all tools are needed tp replace them two gears and the bearings. But also trying to figure out what could of caused this to happen. I don't want it to happen again.
Thanks In advance.
Thanks In advance.
