Fresh Water Pump BROKEN - 96' MAXUM SC2300
hommey
My fresh water pump recently stopped working...
I have a 1996 MAXUM SC2300, and at the beginning of the season it worked fine...
So, I started searching for the problem.
First thing I did was pull the switch, and checked it, it was working fine.
Second, I checked underneth the cuddy cabin faucet sink, to see if I could locate the pump, and all I could see was the plumbing lines going into the bilge area.
Third, I removed a side panal by the toilet area, and I found the tank, but all I could see was multiple water lines going in and out of it. I didn't see a pump, but the tank area was just large enough to put the tank into... I guess I can remove the tank, in hopes the pump is behind the tank, but it would be a project.
Does anyone know where the fresh water pump is? I can't find it...
Does the boat have a fusebox? perhaps the fuse blew.... If so, I don't know where it is...
Thanks
45Auto
Re: Fresh Water Pump BROKEN - 96' MAXUM SC2300
There's usually a fuse panel under the dash. May have to lay on your back to get to it.
Not much help on the pump location, but it shouldn't be too hard to follow the water line from the sink till you find the pump.
