ignition switch replacement
fitzroy97
I have a 85 470 that I have converted to an alternator charging system. At times the ignition switch will not turn over the starter no click no nothing. I have can jump it at the solenoid and it will start in the on position. I have pulled the switch the terminals look good. I have found similar 3 terminal switches here but am confused on if any similar switch will work? some say for magneto charging style systems it was am I correct? Any help would be appreciated.
Thank you
Doug
Bt Doctur
Re: ignition switch replacement
almost any standard 3 pole ign switch will work,OFF-ON- START
fitzroy97
Thank you,
I didn't want to make another problem with the wrong switch
