krisnowicki
Thread starter- Joined
- Jul 11, 2007
- 1,172
I am doing the OMC to Merc swap much like the one done by HT32BSX115. The boat is a 1992 Liberator with a 454 originally in and King Cobra outdrive. ( the daddy king cobra) I bought a donor boat a Formula 26' ( the front was wreck but the power was good.) I chain sawed the transom so I have everything that was used on this boat to move to the liberator. I have a new longblock that I will swap everything from the donor to. I also got a merc shifter and trim pump. I will post updates to this thread but will use seprerate threads to ask questions about the gotchas I encounter to try and keep it short as I know Don S hates long run on threads and his help is and has been invaluable.
This is the album where all the photos will be stored
http://picasaweb.google.com/krisnowicki/NewFolder#
This is the boat...
http://cgi.ebay.com/ebaymotors/ws/e...ageName=ADME:X:RTQ:MOTORS:1123#ht_1533wt_1165
What I have done so far.
Removed the Cobra outdrive and sold it
Stirpped the new transom down to the barebones
painted all the transom parts Alpha one gen 1
I am going to replace the hose, elbows, shift cable, gimble bearing and change the lube and pump and housing in the drive. Also, put on new anaodic bolts and transom gasket when I reasemble.
The engine is a new longblock that is on a stand it gets new manis and risers, starter and oil and fuel pump. Is there anything else you would replace right now? everything else works fine. couple of q's for this thread
Oil pump did not come with the piece that connects the shaft and pump , did the hammer and wrench trick to get the pick up and the pump together and it is setup just like the old engines was. Can you reuse the guide between the pump and shaft and if not you think napa would sell this?
Is there any way to tell if a coupler is and will be good? This one looks great but I dont know how to tell.
The windage plate, two of the bolts that we on the old engine are not on this so the last two holes on the windage plate will go unfilled is this a problem?
I have two carbs a holley 4160 that is on the 454 and a q jet that is on the 350 If I use the holley I will need a new intake because it is not spread bore but, would I need to rejet the 4160 if i swap from a 454 to a 350?
Thanks thats all for now.
Kris
This is the boat...
Kris
