FFScott6
Thread starter- Joined
- Aug 2, 2007
- 136
I have a 1963 Aristocraft "Funliner 17" In our case the name rings true! Anyway, The bow hook was terribly loose, after investigating deeeeppp under the dash I found that this was the second or 3rd repair to the hook. The last fix was to replace it, at which point someone put a body section of a brass valve under the nut and washer (don't ask, I can't imagine what they were thinking).
My Aristocraft is a double fiberglass hull. Well the valve body managed to pull thru the inner glass leaving me a floppy and very unstable hook all but puuling on the outer hull alone. I've removed the hook via a hack saw and the new one will be here tomorrow. I'm thinking of CAREFULLY screwing a "custom made" aluminum plate fashioned to fit the inner hull contour (out of a 10" X 10" 1/8th aluminum flat stock) that should offer to spread the load inside.
I nned to know what material(s) to use to repair the f/g? I have read the "marinetex" and similar products will fill such areas and prevent crushing in the future? I'm hoping to drill out whatever fix I do and mount the new bow hook before this weekend. It's looking like a great weekend to hit the Chesapeak flats!
Thanks to all for responding.
BTW. she's powered by a 1960 Gale Sovereign 60hp V-4 and with a miss I made 22mph last weekend! (I found/fixed a bad plug wire, now I wanna see what it'll really do). Let me say that 6gal does't last long though. I'll be adding a second tank.
