clearwatguy
Thread starter- Joined
- Sep 9, 2009
- 51
been reading this forum a lot and you guys have already helped me a LOT!
i have an mfg 17 foot trihull open bow and it came with 2 1972 evilrude starflight 125 motors one good mounted and one with a blown piston but otherwise complete.
over the weekend i took her to the lake and fired it up with the hood off so i could check the heads for cooling... (seee? been reading this forum a LOT) well it was not cooling so i retreived and went back to the campsite and there in the woods with this forum, my blackberry and a a coleman lantern i changed the pump and took it back down the next day cooling problem solved. now problem 2 it starts and runs very well but misses and has no top end at all. when i say no top end i mean no top end... i was passed at wot by a guy and 3 kids in a flat bottom with a montgomery ward 7.5 horse seaking... this is my first boat but im thinking it should run fast enough to overtake a riddlin addicted teenager in a canoe
stats (again because i have been reading)
compression test
looking at the back of the mounted motor the right bank of cys was 140 top 135 bottom left bank 125 top 125 bottom.
spark is there on all 4 wires BUT the right bank will jump a lot further than the left bank of cyls
plugs the right bank is black oily and wetish the left bank is clean and dry...
so basically here is what i have. lower compression, weaker spark let completly clean pugs on the left side both cylanders... fouled plugs, better compression and stronger spark on the right side. i dont know if my issues are fuel, compression or spark related!
now i know i need to pull the flywheel but this is where i need help... i dont know what will work to pull the flywheel as far as a puller i was thinking probably a 3 leg 2 ton 12 inch standard puller but im not sure.
second i have no clue what to look for once i get it pulled off other than breaker point gap and coroded connections.
is the compression THAT bad? lol help me obiwan-outboarders your my only hope
compression test
