disconnect s.l.o.w. feature?
qflex1115
O.K. now how do i disconnect s.l.o.w. feature on my 99 johnson 130hp. i guess thats why i'm not getting an accurate reading when i'm checking my timing. any help would be greatly appreciated!! thank you......
Re: disconnect s.l.o.w. feature?
Sonds like you want to disconnect Quickstart feature. Quickstart is the white/black wire on the port head temp sensor. I do not remember if you need to ground the wire or not to take it out of quickstart mode.
ezeke
You need to ground the powerpack end of the white w/black stripe wire to disable QuikStart. QuikStart will advance the timing each time the engine is started, but if grounded, the QuikStart feature will disable in 5 seconds.
qflex1115
ok perfect! thanks guys....:D
