If you will fill this out, I will do an analysis for you.
Iboats Boat and Motor Info
1. Year, make and model of boat 1991 Chris Craft 228 Concept
2. Length, width and base weight of boat, look for boat decal on back of boat 23.5 feet 8 feet wide 3700 lbs
2a.What is the maximum recommended HP for your boat 230
3. Number of people and gallons of gas normally on boat 2 and 35 gallons
4. What do you use the boat for Speed, tubing, etc.
5. Is it a Deep Vee and if so how many degrees of deadrise N/A
6. Year, make. manufacturer and model of motor 1991 OMC 5.8L
7. HP and gear ratio of motor IMPORTANT 1.41
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing then do the same thing on the motor and turn the motor until the tape lines up with each other on the prop, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range 4200-4600
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene N/A
10. Is it a bass boat or does it have a pad bottom N/A
11. Does it have a hydrafoil, dolefin or trim tabs Hydrofoil
12. Make, model, diameter, pitch and whether SS or aluminum prop 15.5x15 Aluminum Mfg unk
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50
RPM _4200__________ Speed ___32________ No. of people ____2________ Gas ____25 gallons____
14. Are you at sea level or a higher elevation, give us the elevation in feet 1100 feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM Just tuned up but carb is getting rebuilt this winter. I don't think it's affecting RPM's
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop Prop has been on since I bought it this spring
17. Does the prop show any damage that you can see small dings on leading edge, pitted, paint mostly gone
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations Faster!
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
3000 - 20mph
3500 - 24mph
4000 - 29mph
4200 WOT - 32 mph
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
