OMC tru course ball type steering cable
mwb
hi
my neighbor is in need of an OMC tru course ball type steering cable & cant seem to locate one
can someone tell me how to approach this OMC steering system problem...
thanks for looking
tim24
Re: OMC tru course ball type steering cable
Is it a single engine ? If so go 2 marine offers a kit to change over to a rack system, If its a twin good luck As for just buying a cable im beginning to believe that they really are obsolete,e If you do find some one who has some or can remake some please let me know thanks tim24
tim24
To be honest im not sure, i believe the system im dealing with is called a over under system and it has the balls /clam shells but the cable is different I dont know if the system they have is adaptable , call go2marine and talk to Mike Weller A very nice man with a lot of knowledge, good luck were in the same boat ha ha tim24
King P.V.
If you/he has TrueCourse type steering (everything is inside the boat) then he's screw'd. If it's the "ball" type that exits outside the transom, then a new cable system plus an adapter kit is readily avaiable.
tim24
Yea mine exits through the transom , but its a twin ,Im looking into converting over to a hydraulic system ,ill have fab brackets etc. good luck. tim24
nealpellecchia
Where?? 1971 fiberform OMC 215 hp 15 ft cable type 2 cable only with ball outside transom.
