help please in don s sticky forum
Status
Not open for further replies.
riverboy460
he has a mercruiser shift assist module picture. i have a 1993 mercruiser 5.7 and alpha one gen 2 drive. i removed all thunderbolt iv igniton module distributor and coil. replaced with performance mallor marine distributor. now i need to wire the shift interupt switch. his pic shows the switch grounded to the engine then the other wire to the coil negative will this make the switch work right for me? i have posted 2 other threads tonite and no replies please help so i can get back on the water thanks.
Apollo75
Re: help please in don s sticky forum
Does that distributor have a coil ?
If it does hook the wire from the switch to the negative side --- the distributor is making and breaking the circuit to fire the plugs.
That switch is a normally open switch and I cannot see how it would work supplying power in the new configuration to run and opening to interrupt the engine spark while you shift ---- ingenuity will prevail :)
Best guess --- sorry :rolleyes:
OFM
______________________________________
"If the boat is not sinking or on fire ---- Relax."
riverboy460
yes it has a coil its an aftermarket mallory marine coil but its similar to tha stock coil. its an electronic breakerless distributor. not sure if that shift interupt swich can be or should be ran to positive or negative on the coil. thanks for reply
Apollo75
If it has a coil --- the distributor makes and breaks that circuit --- by grounding the coil ---- that is the dwell, how long the coil is grounded saturating the coil winding building up a magnetic field --- then the circuit opens --- the magnetic field collapses --- induces a magnetic field in the high tension windings and firing the plug.
The interrupt switch grounds the circuit when the shifter is moved to kill the engine --- so the normally open switch should work on your application --- connect it to the negative side of the coil --- grounding the circuit and killing the engine during the shift.
Good Luck
OFM
Status
