HookMaster
- Joined
- Jul 9, 2006
- 145
I have a '74 Glastron that has side panels attached using a metal female plug inserted into the plywood and when the plywood is coverd with vilyl the panel is screwed from the inside of the gnnwhale with a threded screw so ther is no fastener showing on the outside like when you insert a screw through the panel and attach it then use a screw cap to cover the screw head. I can't seem to find a name or source for these metal plugs.
Don
Don
