Re: Flat Fuel line Bulb
There is a very good chance the bulb is NOT the issue. Any time a bulb gets sucked flat the problem lies between the bulb and bottom of the fuel pickup tube in the tank. If you have a built in tank, you will need to pull the pickup tube and check the screen if it has one. If the tank has an anti-siphon valve (the fitting on the tank to which the hose connects) it may be defective. Remember, fuel is "sucked" through the line so a flat bulb means the obstruction is between the bulb and tank -- not after it.
If your fuel tank is a plastic portable, drain it and look carefully inside. I've seen many of these with bits of red plastic (lots of it) in side. Enough of this stuff has been seen that it clogs the pickup tube and in some cases (one of my own boats) it has punctured the screen and made their way into the bulb. When I first discovered this issue, I began checking brand new tanks at marine stores and department stores that sell them. To my surprise, many of them had this debris in them. It is the shavings from the drilling operations during manufacture of the tank.
