Mercs and such
- Joined
- Sep 13, 2009
- 97
I have a Glastron T 156 15',6" that I recently bought. Being a moron like I usually am, I threw on my 1988 Mercury 115HP outboard. Took her out and you probably knew what was coming next... first big wave I hit and the floor collapsed. I immediately went back to the dock. Took the boat home and took off the carpet. I saw black soggy chipping and deteriorating wood. After shop vac work, here I am stuck with a dilemma. The Stringers are all soaked and foam is original factory foam completely soaked. The transom is peeling and the wood is exposed.
I need to take off the cap I guess or the top part of the boat. I need to know how to get this thing off. Next, should I take out the stringers or do the transom first, and how and the heck you install new stringers and transom. Floor comes last but I have already painted a marine grade 3/4" ply w/ oil based primer 5 times then laid epoxy resin and glassed over 1 side I guess for the side facing the stringers but should I epoxy/ glass every single square inch of it for maximum protection.
Any help would be great. I can post some pics of the boat so you can see what I am faced with.
thanks, M&S
-1976 Glastron V-156 115hp merc
thanks, M&S
