arsenalpsu
Thread starter- Joined
- Dec 1, 2008
- 290
1984 115hp in-line 6cy mercury ser#6441514: I have some water leaking from around my Cylinder cover on my "tower of power" listed above. I plan to remove the cover and replace the gasket this fall. It looks as if i can remove all the bolts and just replace the gasket. Is this as easy as it looks? Any tips or suggestions please?? Also, when i replace the gasket should I apply any grease or oil to it before replacing the cover? Any issues I could run into doing this?
I do know that when screwing the bolts back on they shouldn't be too tight as they can break off very easily. Any help is appreciated!
Thank you!
Jon
Thank you!
Jon
