surfrider123
Thread starter- Joined
- Sep 16, 2009
- 2
I have a 1987 Evinrude 6hp, short shaft, Model E6RCUD, Belgium. Problem #1: It is stuck in forward gear, shift lever will not turn at all, will start and run in forward gear. Problem #2: Lower unit will not separate from exhaust housing. Service Manual says put in forward gear, remove three bolts and slide lower unit off of exhaust housing. Sounds easy but lower unit will not slide out of exhaust housing. Manual is not much help. I have tried prying and pulling but I seem to be doing nothing but destroying the edges of the lower unit. I just purchased this motor and have no way of knowing if this lower unit was ever dropped before. I was aware of the shifting problem when I purchased it but thought I could free up the shaft. So much for the easy fix. I have no choice but to drop the lower unit,the impeller has to be be replaced. Any suggestions would surely be appreciated.
