FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: tach install on 1977 115hp mercury straight 6?
Pretty much any marine tach (auto type tachs won't work) with a selectable "pole" input (6 pole, 12 pole etc). Depending on the controller you have, all the tach signals you need should be right there already. You will just need a tach harness to run from the controller to the tach at the dash.
Also if you plan on using an aftermarket tach which I did in my case I had to run my sending wire to one of the yellow wires coming from the stator.The brown connector on the switchbox doesnt work on the aftermarket Tach
Actually, all you need to do is remove the brown wire from switchbox and connect it to either of the yellow wires on the rectifier. No need to run a new wire.
