iammarcuse
- Joined
- Oct 15, 2007
- 139
I have a 1989 Yamaha 130. It runs perfectly but I keep fouling the #2 spark plug after about 15-20 hours. The plug becomes black and fouls out. So I am guessing that one cylinder is running rich. The pilot screws are all 7/8 out as per manual. The motor blubbers a little at trolling speeds but these high compression motors always do a bit. I have swapped to a NGK BR8HS plug which is one range hotter until I solve the problem.
Any thoughts? Rebuild carb? Reset float? Replace needle valve?
