adjusting trim
KPKID
Does raising trim raise or lower bow. My boat takes water over transom before coming up on plane.
a70eliminator
Re: adjusting trim
Raising the trim (trim out) pushed down on the transom in turn pops bow up.
Lowering trim (trim in) lifts up the transom in turn pushed bow down.
Re: adjusting trim
It is pretty unusual to take water over the transom when trying to plane. What kind of boat are we discussion? What HP?
Sounds like you might need to trim down more.
Home Cookin'
Re: adjusting trim
Agreed. You have something seriously wrong there. Where is all your heavy stuff?
Boss Hawg
Re: adjusting trim
For sure! Start with trim all the way DOWN -- If that does'nt do it you have other issues :confused:
I think we're assuming you're giving it enough gas to push it over on plane-RIGHT :rolleyes:
KPKID
Re: adjusting trim
It's a 14 ft runabout wth a 40 hp merc. It was originally an I/O but someone cut a notch in the transom and put the outboard on it.
