How to tell if you have Fast Start feature ?WOT Timing
johnmark
I have a 1983 johnson 50 hp (J50BELCTA). Was wondering if my motor has this feature(Fast Start). Am thinking of using Joe Reeves WOT timing setting on this Motor. Thanks Guys, John
johnmark
Re: How to tell if you have Fast Start feature ?
Send PM to Joe Reeves hope he Knows.:D
You don't have that feature.
johnmark
Thank You Will pick up timing light today and see how close my 50 hp is.I feel she may be off a little. want to check all i can before getting new prop. Thanks again , John
johnmark
Re: WOT Timing
Thank You I have set the timing as Mr. Reeves said. model (J50BELCTA) . Started her up just fine on muffs ,out of gear. Was wondering what RPMs should I set the ilde on muffs, out of gear? Before I had the ilde set at 750 RPMs on muffs, out of gear.And when in the bay she wanted to and would sometimes die putting her in gear.Hope to put her in the Bay today and test her out . Was only getting around 4200 RPMs @ WOT want to make sure everything is just right before sizing a new prop. for her. Thanks Again ,John
Re: How to tell if you have Fast Start feature ?WOT Timing
Idle rpm and idle mixture need to be set with the boat in the water. Doing so on muffs results in no exhaust back pressure which affects those settings. Idle speed should also be set in the water and in gear. Setting it in neutral results in the engine stalling when put in gear.
johnmark
Thank You ,John:)
