New tach won't work right
rbellingar
Hey there new to this site but not to boating. I've just put a new tach in my boat and it just doesn't seem to respond right. At idle it reads fine then as the rpm's increase the tach increases alot faster. Once the tach hits 5500 it starts to go back down. This is on a 75 evinrude 85hp. The tach is a Faria U.S. Marine set on 12 pole and hooked up to the grey wire in the control box. I've searched the forums and haven't seen this problem so I thought I would see what everyone has to think.
Barnacle_Bill
Re: New tach won't work right
I believe Faria uses pole settings rather than pulse setting so 12 poles would be correct. Test you rectifier. If you are sure it is good and all connection are good you may have a bad tach.
rbellingar
How do you test that just by voltage running and not running?
skippy2235
if you have a 4 cycle engine then:
take the number of poles in the magneto, 12
take the number of cylinders (you dont tell us) =X
Then you take 12 divide by X = pulse number
If you have a 2 cycle engine then:
Then you take 12 divide by 2 = 6 pole
rbellingar
I just finished testing the rectifier and there is no voltage increase at the battery from motor not running to motor running at high idle.
skippy2235
How did the rectifer test out. Is it shorted?
If you are not charging then the tach will not work.
petryshyn
You have a problem with either the rectifier, stator or wiring. Once this is rectified, try the tach again.
If this is a Faria 7000rpm tach, you should be on setting #5.
Note.....Faria recommends a regulator with this application.....
