Re: How do I remove Fishmaster Deck?
No worries, the 4x gun is what you want and you'll need a set (dependant on rivet diameter measured in 32's so a #4 would be for a 4/32 or 1/8 diameter rivet 5= 5/32, 6/32 etc , most rivets (ad) will be 2117 series aluminum although if you can ,find some 5052 or other 50 series if available. You'll also need a bucking bar and a sense of humor.
try and set the regulator on the gun so that you can control it easily with the teasing throttle to deliver the blows from just a slow tap to a brrrrp, with the set pushed onto a 2x4 or some other wood while adjusting the throttle or trying to get the hang of it. Always use a spring to retain the set (.401 dia) and never touch the trigger until your ready to rivet (safety) the bucking bar should be reasonably heavy and pressed against the back side of the rivet with the gun and set held on the rivet head with the rivet head flush onto the material, never touch the throttle without the bar firmly against the rivet, you'll distort and damage the material.
Its gonna take some practice like anything else to get proficient with it so use some scrap and whack some stuff together before you attack the boat with it,
I feel bad and kinda wish I was there to give you a demo or two and a hand with it but like most skills a guy learns on his own once you get the hang of it you never lose it.
so to summarize , put some masking tape on the face of the set, it'll cushion the rivet heads a bit and your less likely to put smiles (damage) in the rivet heads, nice round holes are your friend and you'll have to experiment with the rivet length to finish with an upset rivet 2 diameters wide and a half diameter high, if your rivets are too long they'll dump on you (get pushed over to one side) dont worry you'll recognize it.
none of this is rocket science and Im sure you'll have no problem with any of it and if I can help feel free to shoot me a pm
cheers
