I have a 1971 merc 800. I need help with making sure the timing marks are right. My flywheel has a single row of three dots and a white dot painted on the top above them.
When the #1 cyl is at TDC the timing marks on the flywheel should point at the #1 TDC mark on the cowl decal correct?
The timing belt should be set so that the arrow on the distributor pulley points directly at the three dots on the flywheel is that correct?
I also have a dot stamped into the rim of the dist pulley opposite the arrow and the pulley has a little bump on its lower rim that woudl ssem to line up with a little bump on the casting at some point, what are these marks used for?
I an not get this 800 to even cough and it is driving me nuts. I am humbled as I have never not been able to get something to start.
