I have a 89 Barretta with a Volvo 305 and 285 outdrive. The boat runs great in the driveway with the muffs on but when we hit the water its a totally different story.
This morning I went out and started the boat in the driveway within 10 seconds of turning the key. Let it run for a few seconds then turned it off and started again as soon as key turned, let it run for a few minutes and tried again. Let it run for about 15 minutes then turned it off thinking it was ready for the water. Just before leaving today I started it again took about 2-3 minutes this time but I got it going.
Got to the water put it in and nothing. It got close once but couldn't get it running.
Got home hooked up the muffs and it took about 2-3 minutes and it started again. Ran for about 3 minutes turned it off and it turned right back on. Turned it off and now it has been running for about 30 minutes.
When I was on the water I checked voltages on the ignition coil + side and it was only reading 6 volts.
There was also a water leak that sounded like trickling water when I looked under the engine it looks like its coming from the back of the oil pan or somewhere thereabouts. I have recently changed the bellows and gear linkage flex rubber.
This also happened the other week when we went out. It started and ran great but when we turned it off it would take a good 10 minutes at least to get her running again.
Even though I was reading only 6 volts on the coil it had spark. I'm not sure how much the spark differs from a 6 volt to 12 volt reading but it was sparking.
Please help. Any ideas of what is going on here?
