Bilge Blower Operation Direction
crazy charlie
I have 2 bilge blowers in my twin screw Regal.I am replacing both since they seem to be working at half speed.One is bringing air into the bilge and the other is drawing air out.Does this sound correct??? I thought both should be drawing air out..?? Charlie
scoutabout
Re: Bilge Blower Operation Direction
How many vents does your bilge have? That might help answer the question. If you have two only and they are both plumbed to the blowers, I'd say one should suck and one blow. Otherwise how does the fresh air get in?
If you have other vents with no hoses attached, I'd assume those would be the fresh air intakes and both your blowers should work to exhaust that air through their attached vents.
At this point I should note that I have experience with single blower setups only but common sense dictates the air's gotta get in before it can be blown out...
redone4x4
that sounds correct. the fresh air comes in and the fumes go out at the same time.
RWilson2526
I would agree with Scoutabout, if you have other means (vents) for the fresh air to get drawn in I would want them both exhausting....not sure of the configuration of your engine compartment and if you have an enclosed cabin area in proximity but if the blower that exhausted failed and the supply one kept running you would now be forcing the fumes into an enclosed space possibly.
As well I dont have any experience with this in a marine application but just using some rules that we use in construction and confined space situations....
arks
Charlie-
Blowers can be used either way. Look at the orientation of your vent screens. I'll bet you'll see some facing forward and others facing aft. If facing forward it would be an intake.
THAT will determine which ones are intake or exhaust. You need to make sure the blowers are moving air in the proper direction.
crazy charlie
I have 2 vents across the stern and one on each side of the hull.I assume the ones on the side are for drawing air as I am underway and the stern is exhaust for the blowers.I will have to take a closer look.
Bronc Rider
I cant say I have ever seen one blower "sucking" and the other "blowing". Usually when I see two they are both "blowing" out.
As soon as the fans start blowing it will force fresh air into the bilge, no reason I can see to have a blower to pull air from outside.
rbh
ya know there is going to be a couple of jokes on this subject :D
rob
Bronc Rider
^^^^^Yeah, I think I could have chose my words better. Oh well, we are all adults right?
To exhaust air from a sealed area, outside air needs to replace it. (Suck real hard on an empty soda bottle to prove this theory). To force air in, there needs to be a means of exhausting the existing air. (Blow on an empty soda bottle to prove this theory). Without that, the fans/blowers will cavitate which means they spin like crazy but move no air. If the boat has only two ports and both are fitted with blowers, AND (note the AND), there are other vents into which air can get into the bilge, then and ONLY then should both blowers be in the exhaust mode (sucking air from the bilge and exhausting it). Fresh air in that case would be drawn in to replace that being sucked out by the blowers. If there are no extra vents, then one blower needs to force air into the bilge and the other needs to exhaust it. It is very common to have one vent facing forward and one rearward so that movement of the boat creates airflow into the forward facing vent and air is exhausted through the rear facing vent.
