da_ardvark
Thread starter- Joined
- Jul 31, 2007
- 39
Hello all,
I have an 85 citation with a mercrusier 3.0 L and an Alpha 1 outdrive. The outdrive and motor are (as far as I can tell) the same year.
My problem is that once I adjust the trim limit on the port side, I can get the throttle switch to work nicely. Full down and full up trim. The Problem is that the trialer up switch stops where the trim limit switch it set (21-3/4")
I suspect a bad ground on the trailer trim switch but I wanted to ask the pros before I began the wire tracing.
Am I missing something here?
Thanks in advance for your help.
Denny
Denny
