My QD16 motor runs very well for its age. I checked the gap on the points the other day and they were a little close when I checked them with a feeler gauge, so I adjusted them to .020 and cleaned them up a little. (They looked fine) I took it out yesterday, started on two pulls after setting for about a month. Fired on the first pull, pushed choke in and started on second. Started on first (actually half way between the first) pull each time after that. The problem I noted was that it won't idle very low. Put the GPS on it and the slowest it will go is 2.5 MPH by the GPS. It is on a 12ft alum boat. It seems a little high idle for shifting also. I checked the timing plate base and the end of the base where the roller starts to fall off the end doesn't quite fall off. In other words there is still a little plate left over. Could I adjust that plate a little so it lets the butterfly close a little more? Other than that it seems to be running good. No hesitation and easily planes out the boat with a heaving trolling motor battery in the middle and my lard butt and gear. Checked top speed with GPS and it was up to 18 MPH with more throttle to go. A little too rough water to open it all the way.
