Merc 75 hp 1986 starving for gas at wot
paulo239
I'm running out of ideas. My 86 Merc 75 runs like a top most of the time. Idles, cruises just fine. Occasionally at wide open throttle it acts like I'm running out of gas. If I hit the choke, she takes off for a second, then starves again. Once I back down the throttle, it seems o.k. and will run fine. Punch it and she goes good for a minute or 2. I have new fuel tanks, new gas hose, new fuel pump, new plugs. It needs to be primed big time after sitting for a week or 2. I live in Humid, hot SW Florida. Is it humidity-related? Help! Thanks!
turbinedoctor
Re: Merc 75 hp 1986 starving for gas at wot
Got a serial number?
When at WOT does the primer bulb get soft or flat?
Have you rebuilt the carbs lately and double checked the float adjustments?
Durwood
Fuzzytbay
Just a guess, but it might be the high speed windings on the stator starting to go.
j_martin
If the spark were weak, choking it wouldn't help. Symptoms are about fuel delivery.
I've seen symptoms like this caused by a plastic bottle seal floating around in the fuel tank, occasionally plugging the pickup. Truth is, it could be anything from a plugged vent on the tank (bugs, usually) to a soft vacuum pulse to the fuel pump. When it balks, fuel level in the carbs is declining. Choking it pulls that out in a few seconds, and then it's too low for even that to fire.
The list:
Tank vent
Debris or sludge in tank
decomposing fuel lines
undersized fuel lines (usually on a v6)
fuel pump diaphragm or valves (discs)
fuel (bayonet) fittings
soft or plugged crankcase pulse to fuel pump delivery
dirt in carbs near jets
dirt in carbs behind needles.
Bear this in mind. When it's running lean it can do serious internal damage to the engine. You're not supposed to be able to inspect the wrist pins through the spark plug hole. Lean burn gets a lot of engines fer sure.
hope it helps
John
paulo239
Wow, Thanks for all the great responses! I will get to work... Much appreciated.
