I am trying to repair my bellows and can not tighten the hose clamp without the bellow falling off the outdrive. Is there a tip or trick to positioning the outdrive so that I can reach the hose clamp?
My searching revealed that I need a glue. (None used by the shop that repaird it on July 6th)
Also, can I use an auto glue or liquid gasket as the adhesive?
Thank You.
Thank You.
