1976 Evinrude 25hp... What first?
Milemaker13
So I finally found myself a 25 hp long shaft. The guy started it for me, but only for a few seconds because we had no water hooked up.
Is there anything I should know about this motor? Any common problems to check on?
Where can I get a water impeller for this one?
Thanks guys-
rjezuit
mikesea
Re: 1976 Evinrude 25hp... What first?
breaker points,condenser,waterpump impeller are general maint.parts,usually a once a yr change along with gear oil in lowerunit,if done at a shop,that usually includes sparl compression and many will do a pressure check on lower unit,if your gear oil has any issues like smelly thick tarry consistancy or looks like a milkshake,the gearcase has a leak,its common for ignition coils to eventually go bad,thats the reason for a spark test,with a tester,reliability is only there when general maint is done ,otherewise its a crapshoot as to when points will burn out,condensor go bad or impeller fall apart
