goatkeeper
- Joined
- Oct 2, 2009
- 5
My dad purchased this motor new with boat in 2002. It worked great until mid-2005. He was using it nearly every week. Then problems, it would start and run fine for 30-45 minutes, but then it would die. At first it would crank back and run fine, then gradually it would only go at an idle. He finally got disgusted and quit fishing. This year my son-in-law decided he would take it and get it fixed...after $900 it still does the same thing! Dad has gotten interested again. He thought the pickup tube was hitting the bottom of the tank and cut it off. SO...we tried again yesterday and I paddled over a mile! The motor ran fine for about 45 minutes. We ran through all rpm ranges. Idled. Cut off, started up. Everything seemed fine...then it sputtered once, idled for about 5 seconds and died. After more than 30 minutes of paddling, the motor restarted and acted fine!
Called Mercury tech. They thought it was water pump causing an overheating issue. Does this sound possible? He also stated that the pumps need to be replaced every 3 years...is this correct??? By the way, we heard no horn warning from the motor.
Any help would be greatly appreciated!!!
Thanks,
Jimmy
Thanks,
Jimmy
