kwoolard
- Joined
- Feb 9, 2003
- 420
A friend of mine bought a fixer-upper and has been trying to diagnose a no-start, sometimes hard to start condition. The engine just cranks over as if not getting spark. Then sometimes it will start and when shut down a couple of minutes later it will not restart.
Mercruiser 260 - 4 brl - Alpha
Engine Serial No: 0D391241
He has changed plugs, cap and rotor, and plug wires. He has gone through the ignition checklist to determine the problem and has 12Volts to the coil but when checking the red/white wire going to the distributor at one point he got 0 volts, then bumped the motor to change the position of the rotor wheel and got 5 volts. He then tried the spark check coming from the coil with a spark tester by disconnecting the green/white wire going to the shift interuppter switch and tapping it to ground. No spark was seen in the spark tester. I haven't had a chance to help him out but it seems like the Ignition Amplifier is faulty. I told him to make sure he had a good ground going to the distributor's sensor and to the ignition amplifier and recheck, which hasn't been done yet.
Are these Thunderbolt IV ignition modules prone to fail, somewhere I read they are not as reliable as the TB V?
Do you think this could be the amplifier going bad?
What causes the voltage to read 0 volts then 5 volts after the rotor was turned a little?
Why does the test state 1-12volts at the red/white wire and not 12volts continuously?
If it is the amplifier, has it been superceeded with a new model because the part number I get is 15899A 1 and it states it is no longer available?
What is the correct amplifier part number?
