Rebuild fuel pump??
JFoshee
We put the engine in the boat last night after rebuilding and got ready to crank it. NO fuel. The fuel pump is not pumping. Lines are not clogged and new water seperator on it. I can blow fuel through the seperator and fuel comes out at the "in" line on the pump(when taken off). The pump has a row of bolts around it. Is this rebuildable? Where do I get a kit? Can I take it off and put a 12 volt pump on it?
Re: Rebuild fuel pump??
Ayuh,... That's the Problem,... I haven't seen the parts available in Years....
Anything is Possible, but with it's Own Problems....
Replace what you've got with a fresh copy....
JFoshee
Thanks. That's all I needed to know.
