Repowering Advice - 17ft grew 1975-1981
trendsetter240
I'm seeking some advice on engine HP, Weight and prop selection to repower my 17ft grew boat.
I'm not certain of the exact year and model, only that it is fiberglass over plywood and is quite heavy (maybe 2000lbs?). The boat has a 20" transom and is a deep V hull.
There is no plate on the boat to show the Max HP rating so I used the (L X W X 2) - 90 formula to come up with 114 as the max HP.
The only outboard that I've been able to test it with was a 50HP Mariner. With the 50 it would plane easily with only me and fuel etc onboard and max out around 22MPH at WOT. With two people it would still plane but only reach about 18MPH. 3 people and gear and it would plow through the water at about 10MPH.
My main concern with a new motor is weight. The newer 4Strokes and DFI engines weigh 50% more than the older 2 strokes. With the 50hp I could stand on the stern and water would be about 3 inches below the scuppers.
My second concern is fuel economy. Using the boat with the 50 I had to keep it at WOT almost all the time to get where I wanted to go and this was burning a lot of gas. 5.5GPH at 22MPH is not a lot of bang for your buck. 5.5GPH at 10MPH is brutal!
The boat will be used for fishing in saltwater within 5 miles of the west coast and in tidal rivers. I'd like to be able to take 3 people plus myself and gear and be able to run about 30MPH between 3500 and 4000RPM. Is this realistic?
What would you recommend for the above scenario, being a safe and efficient setup.
Thanks in advance.
26aftcab454
Re: Repowering Advice - 17ft grew 1975-1981
115hp etec-you will have no worries other than purchase price.
ezmobee
Sounds to me like a 90-115 would be fantastic on that boat. If you are concerned about weight, I think Yamaha has a 3 cylinder 90 that probably doesn't weigh too terribly much.
trendsetter240
Hey guys thanks for your input!
I just priced out the E-Tec 115 and 90's and they are way out of my price range for the moment. They look and sound amazing though...
I'm going to start shopping around for used 90 to 115 HP outboards.
So far I've found a 2009 Merc 90 EXLPT 4S (lease return) for about 6k including controls and a 1988 Yamaha 115 for about 2k including controls.
The 88 yamaha looks in decent shape and has even compression around 110. I doubt it would be very fuel efficient though at that age.
The search continues...
