psteurer
Thread starter- Joined
- Nov 10, 2008
- 366
I have a 1989 Johnson 20hp. I just order two new drain plug screws for my lower unit since my old ones were getting marred. I also ordered a half dozen drain plug gaskets. When I got my order I was confused. The new drain plugs I got had nylon washers already on them. The half dozen drain plug gaskets were rubber o-rings. I would think the nylon washer could be used many times but the rubber o-rings should be replaced each time you change the lower unit oil. Anyone have a recommendation on which type of gasket is better to use? Which type is OEM?
