18' Starcraft SuperSport restoration
Status
Not open for further replies.
ezmobee
Re: 18' Starcraft SuperSport restoration
The carnage left behind. Gonna have to clean that up tomorrow.
My workbench and garage are seriously trashed.
ezmobee
Last night I scuffed up all my top sides areas to be painted and sanded the deck boards. I didn't get to put on the 2nd coat of epoxy yet or paint. I did, obviously, get those couple holes in the transom that are below deck patched with some JB. So I didn't get all the stuff done I wanted to but quite a bit done. It's cold as heck here but my heater kept the garage above 60. However the thermostat on it appears to be faulty cuz it was kicking it off last night after it got up to a whopping 45. So I took it apart and jammed a screwdriver in it. That kept it running. Going to have to find out if the Dayton will send me a new thermostat.
HopeSheFloats
Nice tin work, you were busy for sure, looks good. Did you use screws on the deck? I see the rivet gun thats why I ask, I know you used that on the bulkheads. Bummer on the rod...cut 'er down and use it for ice fishing :D
BobsGlasstream
Hey ezmobee,
I'll say one thing for those noodles, they sure are colorful. :D
They should keep you afloat. We may need to change your name to noodle man or mr. Noodle. :D
Very nice tin work too.
Really looking good.
Bob
PaulyV
Good Stuff EZ..They look so neat and tidy layin there. Hey it looks like you only notched out 1 rib in your plywood upfront..versus my 3 ribs. Is theae because its an 18'? Keeps ya from steppin on the rib..Pretty sure my ribs are higher than the floor up front.
Should have looked into electric heat..this kero heater has me dizzy as a mo-fo..not good..and stinky.
micks110
That is some of the coolest **** I've ever seen with the noodles! Do they come in a variety of colors or could you just order all blue or all green:D
That is some outside of the box thinking. Nice work
McGR
EZ - looking real good. Nice noodleage.
jspano
ez-noodle
nice work!!!! didn't expect anything else from you!!
Nice noodleage
might have created a new word
what did you use for the bulk head for the noodles?
and do you have a pic of the top cap of your transom?
jasoutside
Nice work EZ! I am also left wondering how you attached the deck? Rivits? Or, maybe just the adhesive? Looks great man!:D
fshngho
EZ that is using your noodle, ( sorry, you can smack me at Tinstock):redface:
I had to go into reverse just now. I saw your transom installed but didn't see the procedure/pics. It looks great but the wood does not look like it is glassed. I must have missed something. Here is an idea, take your leftover noodles, slice them down the length and slip them over any wires, cables, ect that you may have under gunwales, bow or where ever. That would prevent rattleing and would give more flotation. Kinda like "insulating" procedure. You could put pieces on your rods when they are stored to prevent rattling, or your paddle. You could thread a line through them, add a weight, and taadaaa, a structure marker. I gotta stop, I'm scaring myself.:D
Dale
ezmobee
Thanks guys. In answer to your questions, the transom is NOT done. It's just cut and fit. Still have to overdrill all the holes and seal it. I have more pics of that when I got to it. I attached the deck with deck screws. They worked OK. Surely will get the job done. I got the shortest ones I could get away with which was fine except for a couple areas where I needed to draw the deck down more than a little bit. I definitely missed my mark a few times with them (or maybe hit some pre-existing holes) so I have a few extra holes. Not super thrilled about that. But they'll all get filled in with epoxy.
Huron Angler
Nice work:) The deck looks like a good fit.
Is the rod locker about 6-7ft long? Bulkhead on either end?
Just one more thing to do...purposely swamp the rig this spring to make sure you have enough noodles:p
bananaboater
Ensign
Looks like it is fiesta time under the deck. Would love to be around when the next owner opens it up. :D
You should have put a clear plex insert in so your work could be appreciated by all. :) Great fun and functional.
Albert
86 century
Ensign
You are well on your way now. looks great. How big of a hole do think that jb weld will hold in. The reason i ask i am switching from merc to johnyrude and the bolt pattern is different.
North Beach
Good Job E. Looks like you're movin pretty good now!
sprintst
Oodles of noodles dude. Makes me wish I did mine as my pink board is probably going to rattle. I'll probably need to use some spray can expanding foam in spots to lock it in place.
It's amazing how much those noodles can float. We floated our familiy of 5 on a handful of them in the pool.
vegasphotoman
wow that deck looks fantastic in there...greta job! Im sure your ribs are narrow and easy enough to miss on drilling and screwing...dont beat yourself up.
has the trailer been to the bearing dude yet?
Pap's SuperSport
First. Good work as always! She is really coming together nicely.
Second. D*** you you for making such progress, while my boat sits covered in the cold waiting for the next round of snow, you are kicking butt. Shame on you for creating such jealousy! :D
ezmobee
I've been working on the boat a lot this week. Got the topsides and any painted aluminum on the interior scuffed up and painted 2 coats. Taping all the aluminum trim was a pain. The only painting I have left to do is the consoles, transom and splashwell which will be completed once the transom is fully installed. Tonight I'm going to put the final coat of epoxy on the deck including a layer of fiberglass cloth on the seams. First I will measure for my marine vinyl and get that ordered. Once the deck is dry enough to walk on, I may start fabbing up my bow and stern casting decks. I'll snap some pics of the paint after I take all the tape off.
jasoutside
Looking forward to those pics man!!
Status
