I was loking for kit for a # 0385784 fuel pump and can't seem to find one. Even the fuel pump picture in the evinrude parts look wrong. It is the same one as on my 1973 50hp and doesn't use the gasket in the back to block a hole. The 85 is a 85799S.
Maybe this one is not repairable. I rebuilt the one on my 55 hp 1977 but it has just one outlet besides the inlet filter. A gasket plugged a hole when it bolted to block.
This other pump has two outlets. I took it apart and it looks the same inside as far as gaskets go.
Is there a rebuild kit for the double outlet pump?
